Results 1 to 2 of 2
    Oct 2013
    catania
    Default ECM Titanium Help
    Hi to All,
    i'm trying to learn how to use Ecm Titanium,.. in old versione ECM2001 i know how to add a % in a map..
    In the new Titanium i modify the % but i don't know how to confirm in the map.
    Pls can you help me to did It ?
    Thanks for all
    Oct 2015
    UK
    although i am still learning myself you really shouldnt just change % on a few maps there is a lot more to a good map than this.
    i am not a mapper but i would not recommend using just ecm for mapping, use it more so as a helper or to quickly edit a minor thing as it usually only has a minimal amount of maps available
    Winols should really be used to tune correctly unless your a pro and are confidant enough to make your own drivers for ECM
