Results 1 to 13 of 13
    Fec001's Avatar
    Default Doblo MJD 6F3 DPF and EGR off
    Hi!
    Can you please make correct DPF and EGR off in this file? I tried some solution but check engine is on. There was P0403 DTC, I tried to switch off that but MIL still is on without DTC
    Top Poster blokers77's Avatar
    Mar 2014
    Please, try this solution. PASS on PM.
  3. The Following User Says Thank You to blokers77 For This Useful Post:
    Fec001 (5th March, 2018)
    johak's Avatar
    here you go
  5. The Following User Says Thank You to johak For This Useful Post:
  6. #4
    Fec001's Avatar
    with Both solution MIL is on, no DTC.
    johak's Avatar
    try with this should work
  8. The Following User Says Thank You to johak For This Useful Post:
  9. #6
    Jun 2012
    Here for you. Test and report. You have pass in PM.
  10. The Following User Says Thank You to cawadany For This Useful Post:
  11. #7
    Fec001's Avatar
    Quote Originally Posted by johak View Post
    With file v2 MIL lamp is still on. I upload original, maybe my mod cause this... With original file I have only P0403 DTC
  12. #8
    johak's Avatar
    not the problem in your file
    maybe my dtc off solution does not work on this ecu
  13. #9
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    mil is on because you need reset dpf with mes ....
    DSG TUNING
    File Service
  14. #10
    Fec001's Avatar
    Quote Originally Posted by maajkii View Post
    That was the first thing what I tried.
  15. #11
    Fec001's Avatar
    Quote Originally Posted by cawadany View Post
    Your solution seems ok, no MIL lamp after start.
  16. #12
    Jun 2012
    Quote Originally Posted by Fec001 View Post
    It's wonderful
  17. #13
    Feb 2019
    maybe you can help with mine mjd6f3
