Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 119
  1. #31
    DO I NEED ANOTHER FILE OR WILL THIS ONE WORK AND OPEN THE PROGRAM ? THANK YOU GUYS IN ADVANCE
  2. #32
    Top Poster torqueman's Avatar
    Canada
    hi all,
    I have a question regarding resetting ASH Acummlation on Detroit ddec V/VI engines as am using DDDL 7.04 and after replacing DPF filter on truck my software DDDL 7.04 cannot reset the Ash accumlations.
    Don;t know what to do. dealers are doing with 7.03.???
    Sombody Can help me.
    Thanks In Advance.!!!
  3. #33
    DK Veteran hercamp's Avatar
    maybe not...they are running with it ..with updates ..ado for some models connected to net.
  4. #34
    Junior Member rasteiro's Avatar
    hello mate
    i need some help how can i use the crak i already trie and is asking for the hardkey
    tanks in advance
    i have the ddrs 6.10
    Quote Originally Posted by hercamp View Post
    not at all true in DDDL 7.4 the crack not work..
    and for all that have problem with keysupllier ...u need to replace the file ...not copy and paste...
    extract the crack file to desktop and open Crogramsfolders/detroit dies.../reprogramingsist/ddrs or drs..folder and take the crack from desktop and put in detroit folder ....when need to replace folders press ok and thats all.
  5. #35
    South America
    I get this error msg. Any idea?
  6. #36
    yeah that happen when u try to put key for drs in ddrs or ddrs in drs.
    need to put the key for it ...and not same for both.
  7. #37
    Canada
    hey Guys,
    You need to update the dddl 7.04 with update patch and it will work fine.
  8. #38
    South America
    I dont have update patch
  9. #39
    Canada
    Here is link for DDDL 7.04 patch and enjoy.
    http://rapidshare.com/files/422057922/DDDL_1042_SP4.msp
    If it works don't forget to punch Thanks:
  10. The Following User Says Thank You to torqueman For This Useful Post:
  11. #40
    Member Texas149's Avatar
    USA
    Anyone got any updates for this DDRS 7.03?
  12. #41
    Hi guys D.K. I have problems with my DDRS 6.10 does not work. UNKNOWN KEY HARDWARE SUPPLIER. Please help
  13. #42
    DK Veteran Poptest's Avatar
    Sep 2010
    Quote Originally Posted by jabkissmya View Post
    only works up to ddrs 7.03, 7.04 and up requires server login.
    this file will crack both drs and ddrs! enjoy
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Hi Jab..... I just installed your crack and it opens drs 6.14. However, it takes too long to open, and displays "loading panels".
    Is this because I'm not hooked up to an engine?
    Thanks...........
  14. #43
    Top Poster kimoe's Avatar
    Default DRS
    Quote Originally Posted by Poptest View Post
    Thanks...........
    Yes, If you see Loading panels Display , it Means you are not connected to the ECM .
  15. #44
    Sep 2010
    Quote Originally Posted by kimoe View Post
    Aaah I see. I was working on the software at home. I will connect to an engine tomorrow.
  16. #45
    Top Poster Juanincho's Avatar
    Aug 2010
    It happens in the case you have the usb-link as the interface for the soft. Simply connect the usb-link when loading drs and it will speed up. In other words, connect the usb-link before loading drs. There's no need to connect to an engine.
