Good luck ...
Good luck ...
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
Thanks Dragon hopefully someone can chime in with a solution or where the crash data may be. I looked through a couple forums and someone said on lines e80 and e90 put "00" but i have not tested that on the vehicle yet. I believe it is more than just 2 lines. ugh why cant this be as easy as the older nissan 93c76 or 66 eeproms
Found a solution by comparing another q50 crash and clear. Will post with results later once module is installed.
First U need more help other members and then no problem with clear crash like this ...
Best regards.
Dragon
1111usedcars (23rd May, 2019), huzefa (12th June, 2019), TimsGeorgia (2nd November, 2019)
Tested working solution, No need to do seat weight or any configuration. Please download and use to compare, thank/rep, and pm for password.
1111usedcars (23rd May, 2019), agregento (30th October, 2018), akravtsiv (25th November, 2018), FlyJet (10th June, 2020), ivyura1977 (2nd October, 2018), janushaan (10th December, 2018), Limard (12th June, 2020), MaksimusDM (26th July, 2021), michal0 (24th April, 2023), Pavel-DN (22nd June, 2018), pavlysik (10th November, 2022), slavax (11th September, 2019), splintercell123 (9th September, 2020), supana (7th May, 2018), SvenR1 (11th April, 2018), tima (19th October, 2018), TimsGeorgia (2nd November, 2019), universidadapec (28th June, 2018), vitaliyl (12th March, 2020)
can I have the pass for the file . Thanks
Can I have password
pass please
Don't forget hit thank button if i helped.
hello!pass please )
Send me a private message with our email so i can send you the file. I forgot the password to this file.
can i please get password?
