Results 1 to 8 of 8
    Oct 2017
    Default Modifying Revo tuned stage 1 to add pops and bangs
    just a quick one,
    i have a revo tuned 1.4 tsi skoda octavia 2014 with revo stage one with med17.5
    customer want to add pops and bangs, can i read it on boot mode and do the pops ?
    is it true that revo and apr can not be modified?
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    revo file cannot be modified....
    you need flash frf , make custom tune and then add pops and bangs.
    DSG TUNING
    File Service
  3. The Following User Says Thank You to maajkii For This Useful Post:
    bigjay88 (12th March, 2018)
    Apr 2016
    Quote Originally Posted by maajkii View Post
    Have you seen a MED17 Revo file already?
    They tune with their own unique coding.
    In MED17 revo mapped cars normally i just delete DTCīs and keep the ecu tuned file.
    If i can do that it means that most likely itīs possible to add the pa pa pa pa pa pa pa pa file!
    You will need to read the ecu and have the corresponding original file for it, after that just do a boot backup to be safe and flash it by OBD.
    Pops and bangs with bigjay88 contribution to the forum just ainīt gonna happen..
    BR.
    Michael
  5. The Following 2 Users Say Thank You to SpecZ For This Useful Post:
    bigjay88 (12th March, 2018), maajkii (8th March, 2018)
  6. #4
    maajkii's Avatar
    Mar 2017
    ok, maybe you are right.
    for shure last time i try to touch MED9.1 Revo Stage3+
    after any changes car not wanna start because revo chks algo.
    DSG TUNING
    File Service
  7. The Following User Says Thank You to maajkii For This Useful Post:
  8. #5
    Apr 2016
    Itīs rather complex because obviasly i (and the rest of the world) donīt understand their code, and itīs rather impressive to watch what is made..
    But making some modifications works (cat off, dtcīs off, rpm limiter increase to allow DSG proper tuning for example).
    Had some issues on EDC15 and ME7.5 not in MED9 but i know some guys that did.
    When apr, revo or similar always safety reading first!
    BR.
    Michael
  9. The Following User Says Thank You to SpecZ For This Useful Post:
  10. #6
    Oct 2017
    I have tried to read it, KESS said ECU is protected.
    I thought about going to bench, one of my colleagues told me even on bench you can not read.
    kess did not even accept to read ID.
    i did modified a revo EDC15 once, no issues, but MED 17 this was my first and could not carry on.
  11. #7
    Oct 2017
    yes it is MED 17.5.21 mate
    I had another APR tuned car, same thing happened, KESS did not read even ID.
    will boot mode break their encryption or it is the same like OBD ?
  12. #8
    yamomoto's Avatar
    Oct 2015
    Dump APR tuning MED17.5 can be read through boot-mode on table.
    Then write another dump to the block. Everything will work.
    If you write dump APR again to block, it will also work.
    If APR dump is written to ecu of another car by OBDII connector, it will work,
    but multi-mode RON90, RON95 and RON98 through "cruise" button will turn off.
    In this case, a correction is required.
