Results 1 to 8 of 8
    Feb 2018
    Question EDC16CP33 Nissan Qashqai - does it work via OBD in KESS v2?
    Does KESS v2 support EDC16CP33 over OBD for reading and writing? I have read some posts which suggest there is an issue with injector codes clearing on read and write, is this also the case when using KESS?
    Sep 2016
    today tune by obd without problem....
    FILE SERVICE
    Feb 2018
    Quote Originally Posted by voltechcar View Post
    Thanks, I use an older version of KESS. Mine is firmware 5.017 and Ksuite 2.23 I believe.
    Oct 2017
    make sure u read injector codes first
    Feb 2018
    Quote Originally Posted by autoSP View Post
    Thanks, how do I do this in kess?
    May 2017
    Turkey
    Quote Originally Posted by marsbar View Post
    Reading ok. But cp33-cp34 is really so hard ecus on obd2.
    Magpro2x17 was kill a edc16cp34 on obd.
    If you have ktag, you can do it with bdm method easly.
    But you have only kess, turnoff the dashboard for 3 minutes after writing.
    Also, you must use power supply for remapping. Car voltage will like 13.5v.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Clear your inbox, i cant reply to your message
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Trstenik - Thun
    Default EDC16CP33 Nissan Qashqai - does it work via OBD in KESS v2?
    Also Galetto v54 can easy read/write this ecu by BDM . I did many without any problem.
