Results 1 to 8 of 8
    Member rambobo's Avatar
    Dec 2016
    Romania
    Default Audi A4 2001 1.9 TDI 131 HP AWX EDC 15 HOT START
    Hi, i need hot start repair for this ECU.
    Audi A4 2001 1.9 TDI 131HP edc15
    Car doesn't start when it is warm
    Is that a burned eeprom ?!
    Dec 2012
    Belarus
    In flash all is well with a hot start. The fuel is injected at high temperature.Made more fuel, but I think the problem is mechanics.
  3. The Following User Says Thank You to Alexl410 For This Useful Post:
    rambobo (11th March, 2018)
    Dec 2016
    Romania
    I will try and report, many thanks..
    Vasily.U's Avatar
    Belarus Minsk
    It is very likely that there have already added fuel
    Dec 2016
    Romania
    If it is warm, it doesn't start. If i help it with a little starter spray, it starts normally and without any problems. This is why i thinked about iq
    Vasily.U's Avatar
    Belarus Minsk
    Standart maps looks like this
    Dec 2016
    Romania
    all sensors was replaced, no errors in vcds, i will try with the Alexl410 Map..
    Vasily.U's Avatar
    Belarus Minsk
    I think fuel and so too much , try this
    There may be a problem in the tandem fuel pump
