    Newbie wego95's Avatar
    Oct 2016
    Default BMW e90 320d rate tune file
    HI
    I just bought a bmw e90 320d 163 Km, and previous owner told me there is a tuned file in car maked by a tuning company. I read file from car and i think there's too much turbo load , pressure and TQ limiters are bad ,but i don't have enought experience with EDC16c35. I want to ask someone to rate this tune and told me what should be corrected.
    Thanks for any advice.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Far away from good file.. If a company make this file, i advice to close the doors..
    I don't think that this file is maked by a company, this is a test file, and up up up up.
    Wrong Torque limiter, turbo pressure tooo high Driver wish not calculated, only SOI seems be ok
    I don't dare to use this
    It is very important to do good torque limiter on BMW, sure for automatic gearbox
    Regards from Belgium
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  3. The Following 2 Users Say Thank You to sdtsedat For This Useful Post:
    voltechcar (11th March, 2018), wego95 (11th March, 2018)
    alonedark's Avatar
    Feb 2017
    i think is a good file no problem whith this no problem torque whith automatic transmision
    sdtsedat's Avatar
    Jan 2015
    Belgium
    @Voltechcar: What do you think?
    Sedat Garip
    Belgium
    With Kind Regards,
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Friend believe me, i see very different good dyno result pro files...
    Sedat Garip
    Belgium
    With Kind Regards,
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    bad tuning...turbo bad...limiters turbo bad...no svbl...no lambda...torque bad...bad rail and limiters rail...bad ecm cracked tuning
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  8. The Following 3 Users Say Thank You to teamtuner For This Useful Post:
    sdtsedat (12th March, 2018), teerak2uk (12th March, 2018), wego95 (12th March, 2018)
