Results 1 to 15 of 17
Hybrid View
    Mar 2018
    Default KessV2 v4.036 grey protocol after token reset.
    Hey guys I could do with some help here.
    Ksuite stated I had only 9 tokens left and wouldn’t work anymore. I have redone the tokens and all seems well apart from all the protocols are greyed out.
    I have tried everything I can think of with no luck what else could I try?
    I’ll try add images soon
    Aug 2015
    use new SD card
    Mar 2018
    With the new SD card how do i go about doing it?
    Just insert it into the Kess then launch Ksuite?
    Mar 2018
    Quote Originally Posted by dtip View Post
    use new SD card
    Or do i need to add something to the SD card?
    Mar 2018
    UPDATE:
    Tried a fresh SD card same issue
    Added new files to the SD card from a forum still same issue
    Am i right in thinking it needs a new NXP? :/
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    ok so solution is simple
    insert new SD card
    use kess 2.08 program
    then run normal ksuite..
    working!
    DSG TUNING
    File Service
    Mar 2018
    I have tried this and it no work :/
    Also sometimes the car is greyed out then if I relaunch program it works again...
    I really don’t know what to do haha
    Mar 2018
    So this is what I just did...
    1. Remove SD card from kess
    2. Insert new SD card (formatted no data)
    3. Plugged in kess to laptop
    4. Reinstalled ksuite 2.08
    5. Launch ksuite
    6. Still greyed out :/
    I also have a issue where sometimes I can’t press the car? I have to keep restarting ksuite for it to work again
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    My solution. Put any other sd card. Use 208 setup to update plugibs and tokens. When everything will update , put back old sd card back.
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    maajkii's Avatar
    Mar 2017
    and, remember you always need unrar fresh version of 2.08 than use it...
    DSG TUNING
    File Service
  11. The Following User Says Thank You to maajkii For This Useful Post:
    Ignasvw (12th March, 2018)
  12. #11
    Mar 2018
    Okay so again...
    I tried this one more time.
    1. Uninstalled all ksuite etc
    2. Redownloaded new ksuite 2.08
    3. Removed SD card from kess
    4. HDD low level formatted the SD card
    5. Reinstalled ksuite
    6. Launched ksuite and same issue.
    Am I doing something wrong?
  13. #12
    maajkii's Avatar
    Mar 2017
    i can help you with teamviewer, but tomorrow.
    DSG TUNING
    File Service
  14. #13
    Mar 2018
    Thank you!
  15. #14
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    i uploaded this ...use this reseter...use this version of ksuite...
    Update protocols,and tokens...Then start program..Let it update...
    And you are good to go...!
  16. The Following 2 Users Say Thank You to Stelaras26 For This Useful Post:
    Koriba (11th August, 2018), whalla (25th February, 2020)
  17. #15
    Mar 2018
    I will try this thank you
