Results 1 to 4 of 4
    Aug 2008
    Default SID803A Version Help
    Hi All,
    I have a Volvo C70 that has a SID803A 5WS40562A-T
    Does the 5WS40562A-T indicate a software version on the ECU or a hardware change?
    I would like to create a backup ECU and was wondering do I need a SID803A with exactly 5WS40562A-T on it?
    Many thanks
    Vasily.U's Avatar
    Belarus Minsk
    You need SID803A with absolutely any number, tested many times.
  3. The Following 2 Users Say Thank You to Vasily.U For This Useful Post:
    LeoBY (20th March, 2018), tomolewis (13th March, 2018)
    Nov 2017
    Indonesia
    never try this ecu. but i have done to others. same ecu model can accept others software / flash for swaping ecu. for example old ecu iaw6lp1.02 , new ecu iaw6lp1.45 with diffenrent sw number. i can swap or virginize the flash. no problem. so on me744 and sid801 i have done
    Sent from my Redmi 5A using Tapatalk
    Aug 2008
    Thank You again Vasily.U Your helping a lot with my learning curve on ECU's and remapping............ next I need to learn WinOLS
