Results 1 to 9 of 9
    May 2017
    Default Audi A4 Problem.
    Hello guys i have one problem with Audi A4 1.9TDI 116hp PD. Today i try to start the engine but just crank and nothing. So i have Launch and VCDS i check with diagnostics and there is DTC P1612 and many others i will upload photos and i have read it with KESS V2 . Im open for any advices. Thank you!
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    file is 100% ori.
    chks are ok.
    check coding with vcds.
    DSG TUNING
    File Service
    May 2017
    How .... ? i go to 01-Engine In VCDS after 07-Coding and after ask for some Code i find in internet some codes put there loading and return to 01-Engine and nothing ...
    May 2017
    its possible to be something wrong with IMMO ?
    maajkii's Avatar
    Mar 2017
    read 24c04 we make immo off and check it
    did you try to start a car with spray starter?
    DSG TUNING
    File Service
    May 2017
    Ok i will read it tommorow and will post here .
    start spray i have not tried but i think there is no point
    maajkii's Avatar
    Mar 2017
    you can try...
    maybe fuel pump is dead.
    DSG TUNING
    File Service
    May 2017
    will try this tommorow but why this dtc P1612.....
    maajkii's Avatar
    Mar 2017
    wrong coding... thats why. but car should start with wrong coding anyway.
    DSG TUNING
    File Service
