Hi!
Had got customer with non starting car.
MEGANE SCENIC gen 1 PH2
engine 1.9 DTI
ecu bOSH MSA 15
UCH SIEMENS eith motorola HC705
Remote key is 1 button RF with separate transponder 4D64
when car came to me - Remote worked ok but car won't start -immo light on dash was blinking fast.
I have made a new transponder and programmed it to car - then BANG!!! -car works!!! but remote stopped :-(
I heard that transponder(separate) is matched with remote so when I have used another(new) transponder with already used and programmed remote - there is no sync between transponder and remote anymore.
I have tried to resync remote with button but no success - using status data on renault CLIP I can see that UCH(siemens) senses RF signal but not allow to sync the remote.
DO YOU KNOW HOW to solve that problem - special preparing procedure for transponder before programming or renew procedure for remote? or ....only new remote from dealer with paired transponder ? please let me know if You found or heard about solution for this issue.
thx in advance!!!!!
