EDC15C2... Oxygen Sensor...
1. Faulty pre-glow.
2. Clogged intake.
3. Leaking injectors (from nozzles)
4. Low compression.
5. Incomplete regeneration (last time, every time).
6. About the EGT sensor... have you DTC for it? If not, this version probably is equipped with only one from factory.If yes, check the lines to it for connectivity.
And finally... simply make FAP off (only file) and drive the car (aggressive) 50 km, then let it to cool down and test how is the next morning.
