Driver airbag it means the airbag from steering wheel.
You need to dismount airbag from steering-wheel and look at connector.
I bought my clio at an auction and the airbag light has been on for a while now so i decided to download some software (DDT2000) and buy a KKL lead so i could run some diagnostics.
There were 6 airbag faults that the program could not clear. I think the car may have been crashed and repaired so i sent the airbag ECU to be reset.
There is now only 1 fault when i scan it. The program displays them in french and the fault reads Airbag - AB82E_X65ph2 PPBoucle avant conducteur. Translated using google the fault is Driver Airbag Loop (Open).
Does anybody know a possible cause. Could it be the connections under the seat. I have disconnected and reconnected them and it has not helped. I soldered the passenger side wires. Should i do the same with the driver side?
Hi,you have two connectors,one before steering wheel and other after directly on airbag.
Could be this piece(dont know english technical name ) interrupted or bad contact.
high resistance between connections. check with multimeter on ohms test after continuity check,use crocodile clips from one end to the other ,the reading should be no higher than 3ohms if its jumping up& going in to higher readings irratticly the wiring wants changing .thats high resistance high resistance
The message using DDT200 is
<LI class=tdmecu>Airbag - AB82E_X65ph2 Failures detected
I do not use clip so i dont know if that makes a difference to the error reading
