Results 16 to 30 of 38
  1. #16
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Always is better to remove the chip....
    Tl866 is very good and cheap programmer but always must choose the correct brand of chip...
    It give wrong dump with incorrect selection
    in many cases....
  2. The Following User Says Thank You to Panathaole For This Useful Post:
    Stelaras26 (21st April, 2020)
  3. #17
    Jun 2016
    I am very happy with tl86. Works great. Just stumbled on this thread. Thought i would try this solution and give feedback on my finding on suggested repair for in circuit reading.
  4. #18
    ray-ray's Avatar
    I’m telling you it works like a charm will not scramble the chip. I use it on Saab cim without any worry.. tested..
  5. #19
    Jun 2016
    I will upload pic of bridge. Maybe i did it wrong
  6. #20
    ray-ray's Avatar
    I just remove it and place a metal bridge,simple.
  7. The Following User Says Thank You to ray-ray For This Useful Post:
    Smartita (11th February, 2020)
  8. #21
    Feb 2018
    Quote Originally Posted by ray-ray View Post
    Here it is no more over current issue..
    test it and let all DK member results.
    100% working after your mod!!! thanks
  9. #22
    ray-ray's Avatar
    Your mini pro will now read incircuit, I can also change the firmware from (A to CS)
  10. #23
    Feb 2018
    I have TL866II+
  11. #24
    Feb 2017
    Use Carprog
  12. #25
    ray-ray's Avatar
    It scrambles between 8 & 16 bit mode
  13. #26
    ray-ray's Avatar
    Any one else need tl866 to be mod? Do no load the newest firmware it will crash your unit. The newest firmware has less to offer.
  14. #27
    Jun 2016
    I still only get fffffff with this method. Can it be software version?
  15. #28
    ray-ray's Avatar
    Are you choosing the right chip and is your connection to the ribbon wire correct. Did you clean the chip, is there a dot on pin 1?
  16. #29
    Mar 2020
    mebounne
    Hi, I have just received a TL866II plus and have the newest software. I am having the same issues with the over current reading in circuit.
    So I need to bridge C22, I cant click the pic to get a larger view of what to bridge. l also have the newest software. I'm trying to program my Jeep Jk cluster, 93C76 chip. I am very new to this! Any help greatly appreciated.
  17. #30
    Mar 2020
    mebounne
    I have done the mod, was able to read and save from the instrument cluster without removing the chip.
    Have not removed the second hand cluster that is in my car to reprogram of the original as yet.
    Thanks Ray Ray!!
