Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
  1. #31
    Mar 2018
    Ray-Ray I have a IDpro (mini-pro) that had the c22 bridged years ago that would read in-circuit I also did the Bridge with a TL866II + and version 10.09 (latest firmware) and its reads in-circuit .
    Was the IDPro with v6 a TL866 A? or CS? Whats the benfits of going from a A to CS?
  2. #32
    ray-ray's Avatar
    Same hardware different firmware, idPro has the better of the 2. Also the older software version has better coverage then the new version.
  3. #33
    Feb 2020
    I think i have read someweare the diference betuin tl866 mini pro and tl866 is that can write biger files or smallest with bridge this solved?
  4. #34
    Jan 2020
    Quote Originally Posted by ray-ray View Post
    Here it is no more over current issue..
    test it and let all DK member results.
    I have here TL866II Plus.
    Is this Mod possible for this Programmer?
  5. #35
    Sep 2020
    Quote Originally Posted by Alkinda View Post
    I have done the mod, was able to read and save from the instrument cluster without removing the chip.
    Have not removed the second hand cluster that is in my car to reprogram of the original as yet.
    Thanks Ray Ray!!
    You modded a TL866II Plus? I have one and I can't find C22 .... found C21
  6. #36
    Mar 2020
    mebounne
    Quote Originally Posted by darkfires View Post
    How did you go?
    Did you end up finding it?
    I bridged the chip and was able to read and save, but the transfer to the other chip was not successful, it errored and only copied half the info to the chip.
  7. #37
    Apr 2018
    Has anybody figured out how to bypass overcurrent protection with XGECU T48/TL866-3G programmer?
  8. #38
    Apr 2018
    Quote Originally Posted by armenh7 View Post
    The seller was very helpful. The software has a built in option to increase overcurrent protection. I set it to 350 and it worked.Untitled.png
