danielsandoval (10th March, 2019), lioncam (17th March, 2018)
Hi lion0304 , i hope my question not bother u, i have a Micra 2006 with all lost keys, the locksmith tried to program a transponder with pin code from glovebox with this values: K122128116
B876D4747411
03045155
and he calculate this pin: 774722B9474E
but the transponder doesnt work, my doubt would be: is there some error on pin calculation? is correct this process or the only way to get a valid key is go to dealer?? i appreciate your answer, because the dealer option es very expensive for me thanks in advance
Thanks for ur answer, only twist knob has the car because this start only with the proximity key that i lost (i never use a blade key) - But the locksmith only use a transponder like this 2019-03-10_155153.png , do you think is necessary try with a virgin proximity keys o something else? thanks again
danielsandoval (11th March, 2019)
Until now any solution have worked , even in nissan dealer told me the only way to have a new working keys will be buy all the "starter kit components", but if i buy those new are very expensive, i was thinking buy on ebay ( used parts) i just want some orientation about which components/modules i should buy, how many are? The ECU+Key+Ignition Cilinder or also the BCM ?? If someone can give some information i really apreciate it. I see this: 2019-03-21_124151.jpgwill be enough?? Thaks in advance
tocharprop (30th May, 2019)
Id60 transponder when you put key codes the steering should auto unlock and this will let you programme the keys, in the lost key you need to read immobox under the dash and make key with tango.
danielsandoval (22nd March, 2019)
Thanks super jumbe ans lion0304 for reply, but now i have the follow doubt ¿where is really located the immobox that is neceesary read, on the ECU IMG_8490.JPG? or on BCM BCM8.jpg, or is on both?? Thanks in advance to anyone can five some light on this matter
BCM Read eeprom and make key.
danielsandoval (24th March, 2019)
this system is an big lost of time , if AKL , don't accept this job , Mazda cards too ....
I have made these systems with a Chinese tool "T300" you need the 12-digit pin code, program a transponder 4d id 60 for the emergency key and after programming the emergency key you can program the proximity control
danielsandoval (30th March, 2019)
Here is the manual
