Results 1 to 15 of 16
    Top Poster razor1199's Avatar
    Feb 2017
    Default Focus mk1 1.8 TDDi immo problem.
    Hey,
    I have problem with immo in this focus. There are 2 DTC's that i can't delete.
    B2139 PCM ID does not match between the PCM and PATS control(PATS/ICM/VIC/HEC/SCIL).
    B1681 Transceiver signal not detected.
    I havwe put "new" transceiver from working focus, but there is still same problem. Voltages KL. 15 and 30 are good on ECU and on transceiver, grounds also. Wires between ECU and transceiver are good too.
    Can it be ECU dead?
    I thought keys needs to be programmed once again, but after delete keys I can't learn them again, cause ECU doesn't see transceiver unfortunately.
    Any ideas?
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    dtc is in immo(PATS) or in ecu(PCM)? ecu can be checked by obd?
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
    Jan 2013
    Inside ECU
    Immo is in ecu. Ecu from 1.8 tddi is visteon with pats inside. Check wires again! You have 2 wires from antenna to ecu. Look on autodata i dont remember the 2 pins! So check again the wiers. Check transceiver wires, check ground!
    Nov 2013
    Romania
    On tddi, you look led First adaptation key( you must have 2), and if auto not start and led blink, must adapt ecu pump(fip)
    Jan 2013
    Inside ECU
    Ecu pump is adapted if pump is changed. Is not the case
  6. The Following User Says Thank You to leotdx For This Useful Post:
    razor1199 (17th March, 2018)
    Feb 2017
    @leotdx I have checked wires twice, they are ok, 2 pins between ECU and transceiver are ok.
    @Pyromaniak they are in ECU, I have connected with it
    Meat-Head's Avatar
    ON TOPIC:-
    ADVERTISEMENT:-
    accorfing to to urban rumor a strap on soluaris can verginise the pump take 3/4 hour to do
    where the wires terminate on aerial use xacto knife to press wires in
    rumour states 4 wires, ground, ignition battery live (or another ignition) and one to the ecu who lives down the lane.
    OFF TOPIC:/
    dont think on focus but escort diesel wiring by air intake would chaff on front panel
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  10. #9
    Feb 2017
    Quote Originally Posted by kiszka View Post
    Okay, but what do you mean? I wrote in topic name Focus 1.8TDDi.
    Exactly it's year 2000, EEC-V ECU. I don't need make dashboard correction or sth like that. I just want know possibilities of those trouble codes.
    @Meat-Head thanks, I will bypass wires to ECU and see what's gonna happen. Ground and +12V on transceiver wires are stable
  11. #10
    kiszka's Avatar
    Reality of life :
    4:Everyone lies
  12. The Following User Says Thank You to kiszka For This Useful Post:
    razor1199 (18th March, 2018)
  13. #11
    Feb 2017
    I thought someone had same case as me that's why I have asked for
    Anyway, if I put new ECU and transceiver will I be able to program my original keys in second hand ECU (after erase)? How about pump? I mean is there any dependence in pump numbers and ECU numbers? Or I can put any ECU (ofc from this diesel) to this pump?
  14. #12
    kiszka's Avatar
    Reality of life :
    4:Everyone lies
  15. The Following User Says Thank You to kiszka For This Useful Post:
  16. #13
    Feb 2017
    I have replaced pump many times and programmed it, but always had same pump numbers.
    If I will buy different ECU numbers with keys, the pump should be coded successfully?
  17. #14
    kiszka's Avatar
    Reality of life :
    4:Everyone lies
  18. The Following User Says Thank You to kiszka For This Useful Post:
  19. #15
    Feb 2017
    You have written "I think that it will not be indifferent, which ecu", I can't understand it well, language barrier. This means that I can put to this pump different ECU number (but from same diesel) ?
