Results 1 to 13 of 13
    Jul 2009
    GB
    Default Multidiag 2017 SP5 + Hex for Pic
    Hi everybody !
    Sorry for my bad english.
    Tonight, I've perform to program a pic to work with Multidiag 2017 III SP4
    - First : You have to install Multidiag WITHOUT internet connected. It's not difficult to find it to download.
    Serial to install it : 033918
    Download link : http://mhhauto.com/Thread-ACTIA-Multidia...-sp4-41-41
    - Second : You must have a old interface of multidiag. Black and yellow
    - Third : To program it you have to buy Pickit 3 to connect to the 12F629 with an easy clip without desoldering it.
    - Program it with the VDD + 5v (don't forget to note the oscal value before programming)
    And it's OK
    Need the Hex file ? No problem !
    https://yadi.sk/d/IpuMv0nu3QmHJy
    And the keyupdate :
    https://yadi.sk/d/0d7Tgqw23QmRMb
    If you need help ...Ask !
    Please use THANKS and REPUTATION if my post is helpful...
  2. The Following 15 Users Say Thank You to manu54000 For This Useful Post:
    chipcarcordoba2 (9th October, 2018), d.zio (25th March, 2018), fakhrouch (9th November, 2018), iamuser (13th November, 2018), joe06 (8th June, 2018), khaleddaddi (6th November, 2018), KWP2000 (1st December, 2018), Liteace (14th June, 2018), metsat (19th January, 2019), nabilrifi (15th February, 2019), rui (18th April, 2018), Samsara (25th March, 2018), tigex (10th September, 2018), vasa (13th September, 2018), zaloales (14th August, 2018)
  3. #2
    Jun 2010
    And what about activation
    Jul 2009
    GB
    no need activation ! I tried and test it
  5. The Following User Says Thank You to manu54000 For This Useful Post:
  6. #4
    Dec 2009
    Portugal
    Hello.
    could show an image as it is pickit3?
    I was watching on ebay and found several types.
    thank you
  7. #5
    Jul 2009
    GB
    Quote Originally Posted by rui View Post
    Hello.
    thank you
    See attached files
  8. The Following 2 Users Say Thank You to manu54000 For This Useful Post:
    rui (25th March, 2018), tigex (10th September, 2018)
  9. #6
    Dec 2009
    Portugal
    Thank you for the image to be sure.
    For your description it is enough to have this interface to be able to connect to the cable to reprogram the chip, or anything else is needed.
    I have the cable of the 2013 version and I can not get it to work correctly because it is always saying out-of-date subcription.
  10. #7
    Jul 2009
    GB
    As you can see in the picture, i've attached an easy clip to program the chip with out desoldering it.
    That's all, nothing else needed .
    When you want to do this, ask if you need help
  11. The Following User Says Thank You to manu54000 For This Useful Post:
    rui (30th March, 2018)
  12. #8
    dimitar's Avatar
    You can also use ponyprog or picprog
    Both work and they are easy to make diy
    No need power supply
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  13. The Following 3 Users Say Thank You to dimitar For This Useful Post:
    chipcarcordoba2 (8th October, 2018), joe06 (6th July, 2019), Liteace (14th June, 2018)
  14. #9
    Dec 2009
    Portugal
    Quote Originally Posted by manu54000 View Post
    See attached files
    thank you for the detachment of the image.
    How can I find this card and cable with tweezers.
    As for the interface I have already ordered.
  15. #10
    Liteace's Avatar
    Mar 2009
    On a rock
    Couple of questions, Anyone got a software download link apart from the one at mhh and if I buy new blank 12F629 can I program that ?
  16. #11
    Dec 2017
    espaņa
    Hi and thanks for your help. Can you program this Eprom with Beeprog?
    and a partner is running a 2011 interface with this information from our partner?
    Greetings.
  17. #12
    Feb 2018
  18. #13
    Oct 2023
    Default ACTIA MULTI-DIAG III 2018_43.06
    Hi everybody !
    With crack
    https://mega.nz/folder/jjg3kCYC#ZpmTmmQ-Rnr9XTqIjYJDNw
    Installation instructions - WORKS ONLY ON 32BIT (TESTED ON WINDOWS 7 SP1 X32)
    INTERNET MUST BE OFF
    https://www.youtube.com/watch?v=Cbhq0Vlpc2A
    enjow
