Results 1 to 5 of 5
    Default alfa 147 1.9 jtd 8v edc16c39 disable rigeneration possible?
    hello, i have alfa 147 1.9 jtd 8v edc16c39 , i taked off dpf and blocked egr, i did some mod to exclude egr and dpf from map, car run ok but after 10000 km it start to do regeneration and also oil increased the level, found diesel in oil.
    Can be excluded rigeneration from the flash?
    the dpf-egr-tuned file is the last one i used, the other one is my last mod i must update but im not sure it will disable regeneration.
    someone can help?
    also disable message of change oil and warning of dpf clogged is possible to disable?
    Sep 2016
    so you use ecu safe from forum, cut customer 50% dtc table and you think its good solution? check what he doing in this file. When i do dpf off I change speed limiter for which he start burn dpf, search before matrix maps and he not start burn.
    FILE SERVICE
    here the original file
    Sep 2016
    I have orginal, and what you need?
    FILE SERVICE
