here test and report
iīm not sure i have done it not with remover
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
AUTODIAGNOZA (27th March, 2018)
Thank you very much!
Airbag crash/clear file Service.
Worked great. Thank you again!
Bad news: after driving a while, the errors came back and check engine is on again.
I found the errors tabel in hex, so i will try to disable them from there.
Same dtcs.
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
I donīt wanna get rid off the DTC, i want to code it out cleanly.
Did you even read the article? Its all extcept deleting dtc...
Did you read it? Does it contain any valuable info on valvetronic? Well, obviously not as its ME7.
First of all you should read this topic which actually has nothing to do with valvetronic off...author wants 2 cat dtc off...you should read before writing....secondly you did not mention also you want valvetronic off...you should write what you want...thirdly you need damos for disabling valvetronic and some experience with damos usage...id really recommend anyone who has no experience with motronic to just unplug eccentric sensor and delete dtc
