Hi guys.. Here I have strange problem with psa visteon dcu 102 from boxer..first ecu made egr off read write no problems in proces..car dont start and cant reach by obd..take back ori file and same problem(no start,no obd comunicate)find virgin file online also no go...than I find second hand ecu made backup virginize the file and gess what?same story...ecu killed again and no reach by obd..I tryed read/write with all tools in my hand ktag,kess,fgtech all same story...I heared lot of people had this problem iven with magpro x17 after boot mode ecu dead so I am wondering if anyone now whats killed inside ecu or how to bring it back to life?thanks advanced
digital320 (26th March, 2018)
Ktag Read write ok and chk ok.
Wysłane z mojego SM-G390F przy użyciu Tapatalka
did lots with ktag no problem! maybe your power supply is problem? or using wrong diagram?
thanks mates..exactly..very strange why my ecu is dead..power suply is 13v like always and diagram used from ksuite and fgtech..I try xprog also but same story like ktag..ecu not respond on obd and iven with original file.I read some stories here on dk few peoplw had same problem after boot mode with magpro x17 but nobody write final solution at end..Ihope somewone will now how to bring back ecu to life
can i see ori file of any of them?
yes sure..here ori read and virgin galletto format and one file virgin ktag format..
If the ECU is dead by OBD and it's 10F256 I would verify by TX/RX mode by Xprog
how do you mean verify?I did try xprog also read,erase and write virgin file went smoth....but why ecu dead at first place when read flash and write flash by ktag?you mean replacing the st10fxxx will help?
After found the ECU as dead, is xprog read/write still possible ?
yes I.D. from ecu steel detected...and read write posible many times no problem
So that I would next check Kline convertor circuit. In the meantime of last reply I practiced more to find it on the board, usually with an soic-8 chip but I could not find it and found no any chip link to Kline pin, those visible three of them are not! If you totally remove the board from case you may check the underneath.
ok I think you mean LS93xx chip but acording to this ecu should not respond on k-line?I can read and write many times on k-line and can-bus....very strange what could be killed inside this yunk ecu..I write minimum 5 virgin files...and original file not a single one worked
Ok, just realise that on ktag and fgt there are both connection modes, can and kline (I used Piasini which only kline or Xprog TX/RX). And your might carry out only via can. Now, good to recheck by kline to see if it work ?
yes I test piasini also before...I check k-line and can bus separetly and I am teling all works in boot mode...diagnostic on bench or car ecu not respond
