What is the history of this vehicle.
Lost key. Or some other failures?
If you are in BG. You have all the companies around you.
I have the key I just trained new but wrongly recorded 7bit
Аnd the problem is that I can not now move the car
I only need 10 minutes ignition on and I will fix it but I do not know how to include it so I ask here if there is aanother solution
Do it on bench from CCM behind glove box or bypass ignition with fuses - in document below you find what to bridge
http://www.istanbulanahtar.com/wp-co...ag_en_0414.pdf
nil (18th May, 2019)
the fuse does not go off, ignition on but does not include all the modules and the time does not start
Does anyone have it virgin file or any update for this module
CCM ( 3c0 959 433 K )
tnx
If i understood werll you had one working key? Strange thing is that YOU CAN't START CAR WITH THAT key. When wait time in immo is active it means you can't start key learning/programming procedure but should able to start car with already working key.... you must have done something wrong...
when I added the new key, the old one disappeared so I repeated the procedure with the addition of the two keys
then test how they work and the new key ignited the engine exactly 2 times and stopped working
and in the third attempt to train learn the keys the immobilizer concluded
I think the new key is defective the transponder or has not properly recorded 7bit
And this key you got from the dealer?
If you get some connection again.
Try only to add the original key, as a start.
Before going further with the new one.
The new one is not original I left it with a disconnected battery until I find some file for mоdul reset
Тhe problem is solved guys thank you all.
Guys if the immo shows 0 key learned and i will prepare 7bit mew dealer key does it need any VCDS pairing or will be the key working without coding?
I bought second hand comfort module and try to adapt it via FVDI2018 as the function is there but unfortunately thee function does not work. It gives me communication failure
