You can change map 4x8 ip_n_sp_is_at like you need.
I've got a polo 2010 1.6tdi CR which idles fine when cold but after a few minutes idle becomes very lumpy. If i increase rpm to 830rpm then it is smooth again. Is anyone able to increase the rpm on this pls? If yes then i will take a read.
Many thanks
if this post was usefull
please press
the thanks button
looly (26th March, 2018)
Thanks. If i take a read would you be able to alter it pls?
please press
the thanks button
Yes sure....
Thanks mate. I'll take a read later and look. If i get stuck I'll post dump here. Many thanks.
please press
the thanks button
You can do this with delpy in settings
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
pike (29th March, 2018)
Hi. I have found the map you were talking about. But to increase my idle (rpm) i don't understant what to modify in the values...?
see attached image : https://ibb.co/47V324G
regards
