Results 1 to 10 of 10
    Jan 2018
    shaftesbury,Dorset,UK
    Default Help Renault Traffic 2.0 !
    Hey guys I know your experts!
    Needing a little help with a Renault 2.0
    Is anyone able to delete DTC P0340 From the ecu? its saying camshaft position error but we have checked the timing and replaced the sensor, I have attatched a read
    can you delete this error? as it wont allow the van to start? thanks guys? it is a really big help if we can get this sorted
    Jan 2018
    can anyone do this? thanks
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Try this one
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Your DTC is certainly caused by the distribution chain. If you hide it in the ECU, engine will be broken a few miles later.
    Greetings,
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    This car has very poor wiring, on engine. I had similar problem some time ago. Check wiring. Its easier than change timing chain
    Jun 2017
    French Jungle
    It depends of the DTC: if it's phase signal missing=> Ignsavw is right probably wire cut, if it's phase incoherency => timing chain
    If u change camshaft there is difference between traffic and laguna. Check how many tooth U have on camshaft under CPS. Somtimes need to change maps for fine engine working
    Sep 2016
    yes when engine is change from laguna I change in maps and all works no need cut dtc
    FILE SERVICE
    Jan 2018
    I tried writing the file but crc checksum in buffer error with kess? anyone able to help
    Jan 2018
    if car goes bang boo hoo, owner is wanting me to get it running any means? is it possible to write a file to ignore this fault completly
