Results 1 to 8 of 8
    Feb 2018
    Default help for me, too much smoke for Punto Evo 1.3 mjt 85 cv
    Hello, i have need help for me. I have a problem with Fiat Punto evo 1.3 mjt 85hp because the car smoke when it is on the minim rpm. I made a defap and close egr, send you file. Have you one specific damos for me?
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    post and ori file to find problem with your car
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    AVDigitale's Avatar
    Apr 2017
    is black or blue smoke
    File Service
    Feb 2018
    it is blu smoke, i think are a post injection problem. Ok that's ori file.
    AVDigitale's Avatar
    Apr 2017
    injectors or bad dpf removed need to check
    File Service
    Feb 2018
    i posted file with dpf removed for to check you and to know if i modified this file good
    AVDigitale's Avatar
    Apr 2017
    are you modified with software right not winols?
    File Service
    Feb 2018
    first i use software but later i correct it with winols because with software egr is Always actived
