Here...
BTW... I can't imagine, that you can do tuning, DPF... but you can't merge two files...
Regards!
Hi to all members!I made a tunning and EGR off on this BUS and everything was fine.......but after a few weeks customer came to me and wanted to put back original software.I try write it with KESS like the first time but ERROR occure when writing!Try recovery but nothing happens..now when i give KESS to find ID it says generic error!!I take out the ECU and readed on BDM but what i saw is that flash is realy realy empty!Could some one help me and join the two files (once readed at first time by OBD whit KESS when everything was OK and other readed whit Galleto on BDM when the ECU is dead)and help me start that vehicle!Thank you in advance!
Here...
Regards!
Thanks mate i try and report back
write this with BDM
Your original file
bobolin4o whit your file Bus don't start i will try whit others and post resault
johak's file is same as mine, the other is different software version.
Did you try if there is comm. with the ECU after flashing mine?
no i will try and let you know
Yes i have a communication but immo lamp light and glow lamp blinks
Which DTC's have in the ECU?
i cannot tell very correct because i read it whit LAUNCH and it gaves me (please research before continue)
i will try whit AutoCom and let you know
I try whit AutoCom but no communication.......i dont know whit what tool to read this Bus
AutoCom must read this ECU just fine.
OK i will try whit one one my colleague to see what will happend
