i have scenic phase 3 year 2015 i want to program card for this car but i can't i use original avdi.the bcm it is x 95.
i need your help please how to program card for this car
Best Regards
Best Regards
if you cant use original avdi than the only way is to the dealer what other option have you got .
Correct me if I am wrong.
But I don't think their is any other developer which has come further with Renault, than the AVDI team.
So if their tool can not do it, a trip to the dealer is the only option at the moment.
I read one member claiming that TC is working on something, to get at the same level as the AVDI. But not there yet.
You are wrong
http://www.immo-tools.lt/en/products/renault.htm
Weasel3 (29th March, 2018)
He's right ! Renault update all BCM after 2014 , changing " HEX request " tool <--> BCM , my ECU TOOL cant communicate ton BCM ...
VERY DISAPPOINTED !
only theft tool can do this job![]()
p1et (29th March, 2018)
i make renault clio 4 with avdi 15 min to read and 25 min to wrrite
yes u have right after 2015 ren ecu tool can make card
spare key no akl
ren ecutool can.t make spare or akl
this is for solitaire have you tested renault tool with 2015 or 2016 i have this tool i am very happy with it .
No tool will do 2015 on AKL by OBD.
Need to read memory from card reader and AVDI will do it.
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
http://www.immo-tools.lt/site/files/...t_ECU_Tool.rar
new updated for 2015+ Clio 4 , someone for test it , and if it's faster than AVDI ( 40 min !!!!! )
Procedure reset protected mode ( PINCODE reading .... not AKL ) !!!!
Afraid to this procedure
doctore (24th August, 2018)
sure it's sounds like a risky business, but i think this guys are professionals in the renault. If i have to do it i think i'll make a backup at least first time![]()
Sir, are you classified as human? Negative, I am a meat popsicle
I did renault clio 4 2016 AKL - renault ecu tool made the card with no problem time 5 min
how do you know if akl or not renault clio 4 2016 AKL
igorr (27th August, 2018)
