Even you delete this error code in the flash, this will not prevent the ECU to cut the injector when the problem occurs...
So - repair the car as should!
ECU is IAW6O3 Marelli.
Please DTC-OFF P0201-02 [injectror nr.1 low signal]
I clear DTC, then 2-3 days car works fine, then DTC return and then engine runs again in 3 CYL, clear DTC work ok, and so on.
Will give thanks+rep.
Ori flash attached here.
thanks!
pike (1st April, 2018)
