write this and report
Hi Friends
I am looking for a tested DFP & EGR Off solution for this Ecu, EDC16CP33 for a Nissan Qashqai 2008, Volta and Ecusafe dont work and may damage the ecu that's why i am asking for a manual solution and the removal of these DTCs as well
ECU : 0281014361
DTC : P0488, P1435, P0641, P0409, P0470
All these DTCs are related to EGR and DPF,
File was read over Obd with Kess
Thanks in advance.
koolstuff (4th April, 2018)
Thanks dude!!!! you always rock!!!
Hello, the file is not good it still is in limp mode and there are 3 dtcs on the ecu, i backed up the eprom using orange programmer and after flashing i restore eprom file. Here are the remaining DTC
P0488, P1435 and P0641
maybe limp mode is for this
P0641 - Sensor reference voltage A -circuit open
can you help me remove the dtc and check if i you can make a file version 2?
test this file, pass pm
bFlash/Kess/Ktag/CMD Master
DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
try this.........
