Results 1 to 15 of 17
    Jan 2018
    shaftesbury,Dorset,UK
    Default Disable Lambda on FORD EEC-V?
    Does any of you amazing people have solution for lambda off on this ecu?
    HW: 2S7ABRC
    SW: WFAFAC2.HEX
    Also is it possible to tune this engine for slightly more power at all or not?
    yamomoto's Avatar
    Oct 2015
    Hi!
    If still relevant,
    what engine?
    What year of release?
    What DTC ?
    P0420 ?
    Regards.
  3. The Following User Says Thank You to yamomoto For This Useful Post:
    kennyash1 (7th April, 2018)
    Jan 2018
    Quote Originally Posted by yamomoto View Post
    Hi!
    If still relevant,
    what engine?
    What DTC ?
    P0420 ?
    Regards.
    2.5 v6 petrol
    2002
    and yes rear cat
    yamomoto's Avatar
    Oct 2015
    Pass PM
    Regards.
  6. The Following 4 Users Say Thank You to yamomoto For This Useful Post:
    kennyash1 (9th April, 2018), morgano (5th March, 2020), MVRH (4th March, 2020), ncapuccio (20th October, 2022)
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Have same problem mondeo 3.0 V6 st220 ecu EECV need to remove rear O2 sensors.
    HW: 2S7AFB
    SW: WDABAE2
    THX in advance.
  8. #6
    yamomoto's Avatar
    Oct 2015
    Attach.
    BR.
  9. The Following 3 Users Say Thank You to yamomoto For This Useful Post:
    Faraday (5th March, 2020), morgano (5th March, 2020), ncapuccio (20th October, 2022)
  10. #7
    Aug 2016
    Default ford mondeo mk3 3.0v6 st220 o2 sensor
    please help remove the rear o2 sensor. Ford mondeo mk3 3.0v6 st220 ecu eec-v
  11. #8
    Sep 2021
    i have same problem
  12. #9
    Digital Under's Avatar
    Oct 2017
    Quote Originally Posted by NIKIKI View Post
    i have same problem
    it is very interesting
    ...keep us informed
    GM FORD DODGE
    tuning - deleting - immo
  13. #10
    Jul 2016
    EEUU
    Hi you inbox is full friend.
  14. #11
    yamomoto's Avatar
    Oct 2015
    Hi!
    Ok.
    I'll see.
    BR.
  15. The Following User Says Thank You to yamomoto For This Useful Post:
    ncapuccio (21st October, 2022)
  16. #12
    Jul 2016
    EEUU
    Thanks Yamomoto!
  17. #13
    yamomoto's Avatar
    Oct 2015
    Attach.
    PM.
    BR.
  18. The Following User Says Thank You to yamomoto For This Useful Post:
  19. #14
    Jul 2016
    EEUU
    Thanks Yamamoto work, cs calculation also. You are great
  20. #15
    Oct 2019
    Default Siemans Ems 3130
    Hi Can you help with Lambda off. Dacia Duster Cat was removed.
