Page 19 of 46 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 676
  1. #271
    Dec 2010
    If you want to use nb you have to program the key.. You can't clone the remote .
    Generate remote using nb remotes and than program it..
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
    Thank you very much, what is the procedure?
    I would like to give it another chance.
  2. #272
    Apr 2016
    uk
    Quote Originally Posted by jaelgti View Post
    Depends on tools you have..
    Get pin code and program key. Truecode avdi..
    Or read bcm eeprom and use tango or similar to program key.write back new file to eeprom. Remote should work as well
  3. #273
    Dec 2010
    Thanks mate, I have pin and others.
    the transponders there is no problem, the car starts.
    the problem is with the command.
  4. #274
    Apr 2016
    uk
    Most Opel cars after 2005 are using in circuit transponders... When you program transponder,remote is programmed as well..
    There is no manual programming or via obd port with diagnostic tool for remote..
    Generate keydiy nb remote and program it.
    10 now wait, door open, close open the door.. Like in the video..
    https://youtu.be/yKVmeYl95Mw
    Remote will work
  5. The Following User Says Thank You to comizelu For This Useful Post:
    jaelgti (5th December, 2018)
  6. #275
    rob h's Avatar
    May 2011
    Aygo 2011, remote made by keydiy, with a V3 pcb.
    I could not get it programmed.
    During the programming, the car reacts to the kd remote.
    After programming cycle, it does not work anymore.
    Only the original remote.
    I tried several Times.
    Could the cars maximum off remotes be reached?
    How to erase all remotes?
  7. #276
    Feb 2014
    When you program, you need all remotes to be programmed at one procedure - which means the old are erased automatically.
    Does the car confirm with one lock cycle or with two lock cycles ?
    One cycle means it has accepted the remote, while two mean it is rejected.
    Try to program just the new remote and see what happens.
  8. The Following User Says Thank You to autoTkey For This Useful Post:
    rob h (14th December, 2018)
  9. #277
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by rob h View Post
    Just new update for c1 107 aygo
    Envoyé de mon LG-H815 en utilisant Tapatalk
  10. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    rob h (14th December, 2018), Weasel3 (17th December, 2018)
  11. #278
    rob h's Avatar
    May 2011
    Thanks for the info guys,
    I Just finnished,
    I made a non v3.0 kd key, using the 2005-2014 Aygo update.
    And it works perfect.
    Door locks cycle 1 time, accepted.
    Tried with pre update kd remote, door cycle 2 Times, not accepted.
    And a big thank you, to the K.D engineers, for this fast follow up.
    Perfect!
    The old original remote kept working, after programming of only the new. No erasing.
  12. The Following 5 Users Say Thank You to rob h For This Useful Post:
    autoTkey (15th December, 2018), lion0304 (17th December, 2018), nenadgorgi (14th December, 2018), PocketHero (16th December, 2018), Weasel3 (17th December, 2018)
  13. #279
    rob h's Avatar
    May 2011
    I need to make a spare remote, Defender 2011.
    10AS Lucas system, 2 button key fob. Plip
    There is a keydiy remote in the menu, land rover 433. N5FVALTX3
    Will this key work on these Defender series?
    And what cheap tool reads eka, and lets me program.
    Some say T300+...
  14. #280
    lion0304's Avatar
    Oct 2014
    Renew Mini original 7945 848Mhz: OK
    Dodge fobik chinese 7961: OK
    ***With PCF7961, need connect 1K between SCL + GND***
    PCF7961 PSA renew failed and change to 7943. BAD
  15. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    doctore (16th December, 2018), hcip (16th December, 2018), PocketHero (16th December, 2018)
  16. #281
    Feb 2018
    Glasgow area
    2006-2008 Range Rover L322 with hybrid Sawdoc immobiliser.
    NB integrated remote (BMW EWS) cloned and working perfectly in seconds.
  17. #282
    Sep 2018
    Quote Originally Posted by lion0304 View Post
    My experiance with unlocking keys:
    - Renault cards with 7941 OK!
    - Megane/Laguna/Scenic with HF OK!
    - Clio Smart Key AES285971998R 4A cant connect to transponder
    - Renault V2 Key with 7961 after 97% shows error but ID of keys changed, so hopefully it is unlocked (dont have tools to check 4A transponder)
    - Renault V3 2buttons with 7961 same as above (after 97% error on smartphone but on device said write succesfully - and like yours LION showing PCF7943 and signal is FSK but i am shure that before was ASK and when i pressed buttons rolling code was going faster..
    It is very sad that they giving to us not tested options. Hope they will fix it soon, i read someone before us had same problem
  18. The Following User Says Thank You to arosta For This Useful Post:
    rob h (18th December, 2018)
  19. #283
    Feb 2018
    Some say T300+...
    How do you go from one version to another?
  20. #284
    rob h's Avatar
    May 2011
    Hello BeatsByMe, What do you mean, which versions?
    i see some offer a discovery model key, with remote inside keyhead. just like the N5FVALTX3 kd.
    To fit with ne75 blade, on a Land rover Defender.
    This company sells you the plip (17TN), or a remotehead key, and a programmer obd dongle.
    These cars remote system, might be different, but the remote might be the same?
    Could someone tell me how to create a all in one defender key.
    Or does a N5FVALTX3 simply work on a defender?
    Thanks, greetings Rob
  21. #285
    Feb 2018
    Hi,the question was toward your upper comment,my bad.You are writing something about a non v3.0 kd which I didn't quiet get?
