Page 40 of 45 FirstFirst ... 303536373839404142434445 LastLast
Results 586 to 600 of 673
  1. #586
    Oct 2019
    I'm trying to clone a pug 107 4D chip to a 4D (DST40). Is this supposed to be possible? Or does it only work with KD 4D chips?
    The original chip is identified as Common 4D Chip by the KD-X2
    The blank chip is identified as 4D+ of large capacity.
  2. #587
    Jan 2020
    I just tried to copy a remote from my 2009 peugeot 407,ce0523 fsk id46.It reads original key,it then takes info from the cars ignition antenna,but then it won't copy this information into my nb remote??It says on laptop screen i need to use a UEC key???this is with kd-x2,with kd900 i get the error in this attached photo.20200218_185059.jpg
  3. #588
    metallo's Avatar
    Jun 2018
    Italy
    you should generate nb remote in remote functions section connecting it to kd through cable
  4. #589
    metallo's Avatar
    Jun 2018
    Italy
    does anyone know if it's possible to clone or code an id47 chip on citroen?
  5. #590
    newone's Avatar
    Oct 2016
    Quote Originally Posted by robbocop33 View Post
    you can not cpoy remote,you generate proper nb remote and then learn in car from obd
  6. #591
    Jan 2020
    Quote Originally Posted by newone View Post
    I can't even get the remote for the door locks to work with a keydiy nb key?It seems to write to the remote but remote then does nothing.I understand copying not working for this chip type,but I thought at least doors might operate?
  7. #592
    rob h's Avatar
    May 2011
    You Will need to Read the pincode,
    Created the correct Keydiy NB remote.
    Then car Will respond tot remote and start.
    This answer is allready given by Newone.
    Try pushing the thanks button,
  8. The Following User Says Thank You to rob h For This Useful Post:
    robbocop33 (20th February, 2020)
  9. #593
    Jan 2020
    Any idea if i'll be able to clone a key with a t5 chip for a Ducati motorcycle?I've only had the kd-x2 for two days,someone just asked if i can do one? :-)
  10. #594
    Sep 2018
    I am a bit mad on keydiy. Yesterday i tried unlock 7953 citroen keyless key and from now that option is not available anymore. They blocked it. Now when you are tryin unlock it sayz "please use new smart remote and generate it" or some. Soon all will be blocked. I understand them, becouse unlocking is not giving them profits, but many people bought that device specially for that option
  11. #595
    Jan 2020
    Quote Originally Posted by arosta View Post
    Its strange you mention that,when i was practising with my keydiy kd900 there were listings for a certain Audi key,then next time i looked in the menu it wasn't there!!!??
  12. #596
    Dec 2018
    Yes you can, its ID11 transponder.
  13. The Following 2 Users Say Thank You to Alpaholic For This Useful Post:
    A22 (21st February, 2020), robbocop33 (21st February, 2020)
  14. #597
    Jan 2020
    Quote Originally Posted by Alpaholic View Post
    Thanks for that,so if the guy brings me an original key with a chip in it i just get the kdx2 to collect off that,then i put key i buy which has the blank id11 in it and put that in the kdx2 and write to it?
  15. The Following User Says Thank You to robbocop33 For This Useful Post:
  16. #598
    Dec 2018
    Yes, must work.
  17. #599
    dimet's Avatar
    MKD
    I need to program remote for kia carnival year 2004 probably 433 Mhz, but I don't know which remote to generate.
  18. #600
    Dec 2018
    deleted, wrong number
