Page 22 of 46 FirstFirst ... 12171819202122232425262732 ... LastLast
Results 316 to 330 of 676
  1. #316
    Apr 2016
    uk
    Quote Originally Posted by rob h View Post
    Query resultaten, after 99minutes.
    To create the clone id48, firts i need to verify the original key.
    Not many customers wait that long!
    There needs to be a way to simply write the transponder!
    I did one 2 days ago..5-7mins.
    Sent from my MI MAX 3 using Tapatalk
  2. #317
    Feb 2018
    Without original key present!
    I totally agree! Customer had to wait 75 minutes for a Chevrolet...They need to hire more people.
  3. #318
    rob h's Avatar
    May 2011
    A big thank you to the Keydiy tech team.
    This morning, a update message told me, calculation id48 now under 2 minutes.
    That is perfect, i am very happy with that.
  4. #319
    Apr 2016
    uk
    Anyone tried honda civic remote on honda insight 2009?
    Key looks same.. thanks
  5. #320
    Apr 2016
    it is possible collect points with kd mini?
  6. #321
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by K1nd3r View Post
    When you generate 1 new remote: 20 points. Only first time points are collected for the same remote.
    Copy 48 is 150 points.
  7. #322
    Dec 2015
    Rafah, Palestine
    yes it is possible
  8. #323
    rob h's Avatar
    May 2011
    Lexus RX300
    Type xu30
    2005 433mhz
    Lock+unlock+pwrdoor, button
    89070-4d101 is the remote partnumber, atleast i believe it is!
    All i find, by searching the kd app is 312mhz.
    Is there i another type i can use?
  9. #324
    May 2010
    Sofia, Bulgaria
    Today, calculation volvo id48- 5 minutes!
  10. The Following User Says Thank You to ovitanov For This Useful Post:
    HeXeN (1st February, 2019)
  11. #325
    Jun 2014
    Fiat Bravo 2007. 1.9JTD
    Copy id48 with KD-X2 doesn't work.
  12. #326
    rob h's Avatar
    May 2011
    Quote Originally Posted by Cesarec View Post
    What does not work.
    Reading, sniffing, calculating, writing, non starter?
  13. The Following User Says Thank You to rob h For This Useful Post:
    nenadgorgi (1st February, 2019)
  14. #327
    Mar 2017
    My mini kd cable went bad so I bought the KD as an upgrade. Doesn't let me do online remotes???? Says I need to be connected to PC. Any solution to this problem?
  15. #328
    Mar 2014
    West Sussex UK
    Quote Originally Posted by ps80l View Post
    If using iOS still need to plug into pc or laptop to generate. If your using android pretty sure you can do online remotes if using the cable to connect device and KD.
    There are some remotes that have different names and numbers but are the same. For example B41TA for Yaris/Hilux is online but if you look it’s listed again as Thailand B41TA Vios that doesn’t require you to be online.
  16. #329
    Mar 2017
    Quote Originally Posted by Cromwe11 View Post
    Ohh.... I just found cable in box. Im able to do on my phone now connecting directly into KD instead of via bluetooth.
  17. #330
    rob h's Avatar
    May 2011
    Touareg remote NB series.
    It is listed in both old zone and also in the common remote list. (A8 Toaureg Porsche Bentley)
    I tried to created one using a multi universal NB key, and failed.
    They state that this mulyi NB can be used for all nb types except the old zone nb keys.
    Why does it fail?
    I use the latest version and updated my tool.
    NB07 NB-ATT-46 succes with this one.
    Please fix this, or remove these from the common remote list.
    2006-2010 The key created, is this one?
    2009-2012 Or this one?
    There is reference to a vag number.
    Anyways, still very happy with my keydiy.
