Results 1 to 12 of 12
Thread: MPPS V2.1
    Mar 2016
    Default MPPS V2.1
    not original
    Mar 2016
    List of car pdf
    Sep 2009
    near Strzyzow
    Has anyone else tested this?
    Top Poster zapdus's Avatar
    Jan 2017
    I wont test it
    Several users tell that mpps gets blocked after 10 uses, wont risk
    Mar 2016
    Not , not work , do not run mpps 18 with v 21 , I bricked , block my , counteor , interface block.
    use only software v 18 allegate , not use my v21, you block mpps.
    regard
    i necessity find firmware to rewrite interface if you have , please to post me.
    don ' t erase allegate software , don't use on v18 !!!
    Mar 2014
    See: https://www.youtube.com/watch?v=PxM55rfns4g
    if mmps v21 locked, you can fix by replacing chip or changing a new main board
    See: http://www.obdii365.com/wholesale/mp...oot-cable.html
    if you need to change chip or main board, contact obdii365.com customer service.
    I'm sure they help you to fix your tools MPPS V18.
    Just contact them!
    Regards
    Jun 2013
    EU
    IF V21 SW BLOCKS INTERFACES THEN DELETE THE ATTACHENT, DO YOU WANT LOT INTERFACES BLOCKED???? ARE YOU DUMB OR WHAT???
    THE BEST HELP YOU CAN MAKE TO ALL MPPS V18 USERS IS DELETE THE V21 SOFTWARE, NOW!!!
  8. The Following 2 Users Say Thank You to morgano For This Useful Post:
    bobolin4o (7th January, 2019), Yhoni (5th November, 2020)
  9. #8
    Mar 2016
    You have reason , cina program
  10. The Following 2 Users Say Thank You to PaoloDigital For This Useful Post:
    morgano (7th January, 2019), Yhoni (5th November, 2020)
  11. #9
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Hello friends, I bought the MPPS_V21 before knowing the blocking problem they had.
    My programmer crashed after a few uses and was no longer recognized by the usb ports.
    Was anyone able to unlock the Mpps_v1?
    Is it necessary to save the chip with some file or does it just work to change it?
    Know anyone what is the correct model of chip to replace?
    Thank you.
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  12. #10
    Mar 2021
    Prague, Czech Rep.
    I have a problem like many of you have had with mpps V21 and I would like to ask, the only solution to a locked mpps v21 is to change the chip or rewrite firmware?
    .....or has anyone solved it in another way?
    Thank you
  13. #11
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by votecc View Post
    Thank you
    just buy v18 china clone they dont have this problem or even better buy the v18 eu clone better quality chipset
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  14. #12
    Mar 2016
    Portugal
    Quote Originally Posted by chrisimerk View Post
    I second that, I bought the EU clone and it works perfect every time, Tried the update from China clone V18 to V21, blocked after 20 flashes,
    The guy who makes the EU clone, a member on here gives a discount to DK members so don't waste your time or money on the china clone.
