MPPS V2.1
Results 1 to 8 of 8
Thread: MPPS V2.1
    Mar 2016
    115
    Default MPPS V2.1
    MPPS V2.1 for v1.8 , work , reinstal driver, forr upgrade problem serial comuniocation search in internet or discussion , mppsv18 good or not
    Mar 2016
    115
    List of car pdf ufficial
    near Strzyzow
    97
    Has anyone else tested this?
    Jan 2017
    43
    I wont test it
    Several users tell that mpps gets blocked after 10 uses, wont risk
    Mar 2016
    115
    Not , not work , do not run mpps 18 with v 21 , I bricked , block my , counteor , interface block.
    use only software v 18 allegate , not use my v21, you block mpps.
    regard
    i necessity find firmware to rewrite interface if you have , please to post me.
    don ' t erase allegate software , don't use on v18 !!!
    Mar 2014
    See: https://www.youtube.com/watch?v=PxM55rfns4g
    if mmps v21 locked, you can fix by replacing chip or changing a new main board
    See: http://www.obdii365.com/wholesale/mp...oot-cable.html
    if you need to change chip or main board, contact obdii365.com customer service.
    I'm sure they help you to fix your tools MPPS V18.
    Just contact them!
    Jun 2013
    EU
    1,190
    IF V21 SW BLOCKS INTERFACES THEN DELETE THE ATTACHENT, DO YOU WANT LOT INTERFACES BLOCKED???? ARE YOU DUMB OR WHAT???
    THE BEST HELP YOU CAN MAKE TO ALL MPPS V18 USERS IS DELETE THE V21 SOFTWARE, NOW!!!
  8. The Following User Says Thank You to morgano For This Useful Post:
    bobolin4o (7th January, 2019)
    Mar 2016
    115
    You have reason , i removed, regard
  10. The Following User Says Thank You to PaoloDigital For This Useful Post:
    morgano (7th January, 2019)
