Results 1 to 14 of 14
    EU
    Default Porsche911 991 25640spi
    Hi all,
    Please, need mileage Porsche 911 991 from 124910km.
    Thx in advance!
    Jul 2016
    Should be fine
  3. The Following User Says Thank You to steveleo For This Useful Post:
    vlk69 (9th April, 2018)
    EU
    Perfect!! Thank You steveleo!
  5. The Following User Says Thank You to vlk69 For This Useful Post:
    steveleo (9th April, 2018)
  6. #4
    Jul 2011
    Hi Steveleo,
    can you help me with 911 too? I need 57000km. Thank you in advance
  7. The Following User Says Thank You to immooff2 For This Useful Post:
    ktome (12th July, 2021)
  8. #5
    Jul 2016
    Quote Originally Posted by immooff2 View Post
    Hi Steveleo,
    repaired it.
  9. The Following User Says Thank You to steveleo For This Useful Post:
    immooff2 (14th September, 2020)
  10. #6
    Jul 2011
    Quote Originally Posted by steveleo View Post
    repaired it.
    Thank you many times Steveleo. Can you also edit operating hours in ECU Continental 5WP46593 EMS SDI 9? Now it is 2974 hours and I need 980hours. AT25128 EEPROM inside. Many thanks.
  11. #7
    Jul 2016
    There is also km in the ECU, not only hours. I made it once manually, but didn't make a tool for it and manully sucks. When i have some spare time i can check again. Pretty sure someone here on forum has it in his tool or a script for it.
  12. The Following User Says Thank You to steveleo For This Useful Post:
  13. #8
    drpeter's Avatar
    The Netherlands
    Check adress 12A-135 for hours :-)
  14. The Following User Says Thank You to drpeter For This Useful Post:
    immooff2 (15th September, 2020)
  15. #9
    Jul 2011
    Quote Originally Posted by drpeter View Post
    Yes, I tried. I changed like this "70 FF 3A 43 01 00 9D DA 00 00 39 39" on the address 12A-135, but on diag still show 2974 hours :/
  16. The Following User Says Thank You to immooff2 For This Useful Post:
  17. #10
    drpeter's Avatar
    The Netherlands
    Ok then this must be another version, hours are calculated normally dec*36000=hex so look in in the dump for a simular value
  18. #11
    Jul 2011
    I was searching, but no result :/ I have found one interesting string, that is from adress E8 to F3. It is "14 16 62 06 15 16 62 06 16 16 62 06" but cannot calculate it to find out what is it. What do you think?
  19. #12
    Jul 2016
    E8 to F3 -> 0x06621614 = 107091476 dez / 36000 dez = 2974,763222... -> wanted hours * 36000 convert to hex (press F5 in windows calc) and enter it in reversed order. reversed means lowest byte first, but you see with the sample value i took from your dataset.
    980 hours would be 0x021A5480. or in correct dataset order 80541A02 (repeat three times)
  20. The Following 2 Users Say Thank You to steveleo For This Useful Post:
    immooff2 (19th September, 2020), MileageAudit5 (21st December, 2020)
  21. #13
    Jul 2011
    Many THANKS Steveleo. You are STAR :-) But, when I wrote this 3 strings "80 54 1A 02 80 54 1A 02 80 54 1A 02" on diag show 0 operating hours. I think there will be some checksum, or something.
  22. #14
    Jul 2016
    i don't know about a checksum. and didn't see one. maybe try slightly other value? Or you do the good old "let the car run for one hour" and read again.
