Results 1 to 14 of 14
    Jan 2016
    Jumping Around the globe
    Default Mitsubishi Lancer Evo Smart Key Proximity Programming
    I am trying to add a spare proximity key to USA specs 2008 Mitsubishi Lancer Evo 10 and it is not working.
    I think I am failing on the pincode, I have tried 8A02, 8A12, 8A22, 8A32, 8A42, 8A52, 8A62 And 1530 with no success.
    i am trying with Obdstar pad2.
    I attached a photo of the remote.
    Anyone can help with the pincode?
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Just try it with Lonsdor
    (How shall I help you, if you don't give the basic infos to me??? Where are the pins what you try, and why are you changing 'em?)
    Were's the dump?
    Jan 2016
    Unfortunately I dont have Londsor.
    What Info I missed Giving? I tried all the pins that I cited in the earlier post. I am not changing them...I am just trying based on info i found on the web.
    I am doing this car by obd, i didnt pull the dump yet
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    I think nobody can help without dump...
    Jan 2016
    I will try to pull the dump and post again.
    HeXeN's Avatar
    Mar 2015
    How did you solve it? I tried today outlander EU 2010 keyless with knob.
    tried pin: 8A02, 8A12, 8A22, 8A32, 8A42, 8A62, 7129
    with londsor, obdstar dp, fvdi
    all tools failed. what is the reason?
    in the middle of the vin is code CW8W while fvdi help shows pin 8A42 for CW0W
    I done same car in the past and all ok (pin 8A42)
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Maybe the keys number is too high, you have to delete áll keys, and you can teach the existing keys. Just an idea...
    Tapatalkkal küldve az én S55 eszközömről
    HeXeN's Avatar
    Mar 2015
    There is no option to erase keys. Anyway I will not do it with tools above.
    ray-ray's Avatar
    Nov 2009
    3 wrong attempt to pin code ecu will be lock.
    HeXeN's Avatar
    Mar 2015
    And what happen when ecu lock? I tried 10 times. Car start. FVDI informs need to leave ignition for 15 min to unlock.
  11. #11
    Jan 2016
    I did it with skp, no pin code needed.
    Did another outlander 2014 with skp also no pin code asked.
    Sent from my Pixel using Tapatalk
  12. The Following User Says Thank You to Locker For This Useful Post:
    HeXeN (21st September, 2018)
  13. #12
    Senior Member sazimam11's Avatar
    Jan 2012
    Praha, Czech republic
    This is because the tool sends a default PIN code to a specific modell.
  14. #13
    Jan 2016
    Quote Originally Posted by sazimam11 View Post
    Could be possible, but i have tried all the possible default pins using other tools and couldnt access the programming. tried with xtool and obdstar
  15. #14
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Sorry, there are two methods: 1st what you wrote, the default pin. 2nd is that the tool can skip the pin process, or parts of security processes.
    For Example Insignia AKL. The usual Way is to delete all existing keys, and add 2 New ones with 10 mins security waiting, with alarm/Horn on. Some tools can skip that, and do the programing without alarm and waiting.
