Results 1 to 9 of 9
    Default C5 1.6 edc16c34 hdi system addictive off
    Hi!
    I need help with system addictive off, I tried DTC off but still fault
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    you have fault in dash or bordcomputer (radio and son on...)...?
    Mar 2013
    I also need adattive off dtc in ecu p1146,peugeot 308 1.6 hdi edc16c34
    figani's Avatar
    Feb 2018
    I solve this problem with lexia... Go on ECU... German word Ferncodierung... Don't no the English word... Go to the field... Partikelfilter und Additiv... Change value... That the car does not have this option... And I don't know longer if I also make it in BSI... I forget, just take a look... And the fault disappear from display...
    But in my case... I got the failure on the display of the radio... Where it is also shown radio, Bordcomputer and so on...
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    lexia diagnose
    coneect to instruments and make off aditive and you are fine
    best regards AVDigitale Electronics!
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Not work, I done In BSI addictive off but still DTC P1435 and display show antipollution....
    gsmik's Avatar
    Oct 2011
    Eastern Europe
    1. turn on additif module in BSI
    2. fill additive module with diagbox or lexia
    3. clear DTC in additive module and ECU
    4. turn off additive module in BSI and FAP
    Sep 2016
    disconnect adp, read dtc and cut dtc + emergency module. thats all
    FILE SERVICE
    Sep 2013
    Arrow C5 1.6 edc16c34 hdi additive off
    Quote Originally Posted by bodzio012 View Post
    Hi.
    If the method described above does not work...
  10. The Following User Says Thank You to pike For This Useful Post:
    bodzio012 (13th April, 2018)
