Hi!
I need help with system addictive off, I tried DTC off but still fault
Hi!
you have fault in dash or bordcomputer (radio and son on...)...?
I also need adattive off dtc in ecu p1146,peugeot 308 1.6 hdi edc16c34
I solve this problem with lexia... Go on ECU... German word Ferncodierung... Don't no the English word... Go to the field... Partikelfilter und Additiv... Change value... That the car does not have this option... And I don't know longer if I also make it in BSI... I forget, just take a look... And the fault disappear from display...
But in my case... I got the failure on the display of the radio... Where it is also shown radio, Bordcomputer and so on...
lexia diagnose
coneect to instruments and make off aditive and you are fine
best regards AVDigitale Electronics!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Not work, I done In BSI addictive off but still DTC P1435 and display show antipollution....
1. turn on additif module in BSI
2. fill additive module with diagbox or lexia
3. clear DTC in additive module and ECU
4. turn off additive module in BSI and FAP
disconnect adp, read dtc and cut dtc + emergency module. thats all
FILE SERVICE
bodzio012 (13th April, 2018)
