After Greeting,
Any one can help who don't have a rapidshare account to upload to other file sharing like:
HotFile.com
And thank you
After Greeting,
HotFile.com
And thank you
Hello all... I have PROSIS 4/2009 in 3 DVD (original, made in Sweden 12-2009) and I need license activation, and installing & activation instructions...
jp 100%![]()
Enybody ? Nobody has crack or activation for Prosis ?
downloaded this did the .ini file edit but can't get it to fire up or get it listed in the start menu, it tells me it is all installed and all the rest
error is as follows
"prosis service system application file has stopped working
A problem caused the program to stop working correctly. windows will close the program and notify you if a solution is available"
anyone any ideas?
is there something else you are supposed to do other than editing the .ini file
running Vista home premium but set up prosis to run on Service Pack 2 which is supposed to be the trick for running XP compatible software in a Vista environment
Don't need
just type prosis and hit ok
good luck
Hello good days, I have discharged this prosis, I have decompressed it trouble-free, play the installer that you bring when decompressing. Himself I install in c: Prosis40, when I execute the prosis.exe in my team ( I have installed Windows 7 ) you make as if you thought about starting up the program but no window does not appear from the prosis, where I order the user and pasword. Please if somebody has any idea that I can make or to check would be very grateful.
Greetings.![]()
Thanks you, sounds great this program!
Will many people many happy with this!
Thank you a lot Abduldon. Great...
Please somebody known something about why Prosis don't start when i execute prosis.exe
Greats and I hope help.![]()
