Results 1 to 15 of 20
    Default mitsubishi pajero 2006 ecu table connection
    please how can i get table connection of this ecu to tactrix open port 2.0,ecu type MR560020 with MH8305F inside
    Samsara's Avatar
    Hello.
    What is the purpose ?
    This ECU has K-Line.
    yes i want the kline,positves,negatves,i just ~~~~ to do ecu replacement,if i can read the old ecu and write to new ecu
    moky's Avatar
    Behind you
    hi
    here ktag pinout
    https://ibb.co/jtTrZ7
  5. The Following User Says Thank You to moky For This Useful Post:
    capi (5th January, 2022)
    thanks,but where should i connect VPP at the ktag obd sucket
    Samsara's Avatar
    K-TAG is not by OBD
  8. The Following User Says Thank You to Samsara For This Useful Post:
    ayllon308 (17th November, 2021)
  9. #7
    moky's Avatar
    Behind you
    of course but pinout is pinout..
    vpp is high voltrage I think +16/17V but if someone can confirm..
  10. #8
    Samsara's Avatar
    Quote Originally Posted by moky View Post
    Sorry, i don't understand.
    There's no VPP access via OBD, only K-Line.
    Kess cannot read it.
  11. #9
    the ecu is thesame 4 sucket like mine but mine each sucket has 3 line insted of 2 line as you gave me
  12. #10
    Nov 2014
    mate post picture of you ecu
  13. #11
    tis is the ecu
  14. #12
    that is the cove
  15. #13
    Samsara's Avatar
    Sorry, your ECU is for 3.5 GDI , Moky and me talking about 3.2 DID ECU.
    Here the connexions of your ECU for K-Tag.
  16. #14
    this is 3plugs but mine is 4plugs
  17. #15
    Samsara's Avatar
    Ok, sorry, check those .
    What is you car model?
    Where are you pick-up this ECU?
