I think only emulator.
makura (13th April, 2018)
unfortunatly the last emulator i have keeps giving me an error "no echo from k line" when i try to program ISN into it.
in this system is transponder coil problem, i used old key which sometimes not run and immo fail, so i dismounting coil, improved pins, take out transponder from key and glued to coil, coil glued under steering column and always engine started. no immo problem again.. You cannot be surprised that k-line blocked because emulator sending his own data. such emulator.. but maybe someone had off solution, when I repaired my case, nobody helped..
I hear CarLabImmo has a working dump for MS42.
I also have the same problem and want to remove immo from MS42.
You can check my thread here:
http://www.digital-kaos.co.uk/forums...highlight=ms42
I tested the file OFF on the thread and its not ok.
Thanks for your help
Does any have dump file from a EWS emulator using atmega 48?
hello, I kind of managed to shoot the solution on ms42 CarLabImmo . but I have everything in the photo and they take up a lot of weight. You may have to rewrite the dump by looking at the pictures. If it's still real, then in 3 days I'll try to attach the photo to my inbox at home
thank you if I helpedgratitude motivates me to help further
PUT THIS FILE REMOVE EWS AND MAKE BRIDGE TO STARTER
Thanks Button And Reputation are much appreciated
Maksym Shcherbakov (30th November, 2018), makura (13th April, 2018)
PASS IN PM
aqua_life (16th April, 2018), BRUNOXXX (29th August, 2022), dodge69 (14th April, 2018), electronicar (20th June, 2019), Maksym Shcherbakov (4th December, 2018), makura (13th April, 2018)
Wil test and report tomorrow,thanks
I need to make immo off to this BMW ECU from E46 328i
ECU is MS42
Can someone help me ?
Astrator (19th April, 2018)
