Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Which are the error codes with ORIGINAL file?
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  2. The Following User Says Thank You to bobolin4o For This Useful Post:
    xCata (16th April, 2018)
  3. #17
    Sep 2009
    Everywhere ............................I'm needed
    This is orig dump reading with OBD.
    I need DPF off and EGR
    DTC in ECU : P0488
    Glow lamp is on
    THX in advance
    Money is not everything . . . when you have enough ! ...
  4. #18
    Sep 2009
    This is good solution , but Glow lamp is on and one DTC in ECU
    P0488.
    I need off tis DTC
    MANY THANKS
  5. #19
    johak's Avatar
    Apr 2010
    Quote Originally Posted by Topman000 View Post
    P0488.
    I need off tis DTC
    MANY THANKS
    your file with dtc off
  6. The Following User Says Thank You to johak For This Useful Post:
    Topman000 (19th April, 2018)
  7. #20
    Sep 2009
    Thank mate
    WORK PERFECT
