Results 1 to 1 of 1
    Jan 2018
    shaftesbury,Dorset,UK
    Default Turbo Issue while replacing turbo 2.5 TDI passat edc15
    Hello
    I changed the turbo on my car from the modified turbo which was a g2052v modified with different wheels etc and it died and now I have reduced boost in the map for the stock turbo to run with smoke..
    it runs okay but its like the n75 duty cycles need to be changed as it boosts hard then the turbo cuts boost and applies making weird noise but I cannot find duty cycles map only boost target and change that...
    i have included my map with reduced boost and the original ghe tuning map made for the car and the original ecu file
    Please see attatched
