Results 1 to 3 of 3
Hybrid View
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default passat b6 abs problem need help
    hi masters
    i have problem with passat b6 abs trw440
    3c0614109p
    fault code 00283 wheel speed sensor left open or short to plus
    i check all wiring ok sensor ok
    then i remove abs and found problem infineon orion c2 burned out for this sensor
    i have other abs different number
    3c0614095s
    original abs coding
    0002322
    other 0013605
    how to coding second hand module?
    this is a pic burned chip....
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Jul 2016
    Vilnius
    Can you provide a snip of VCDS autoscan with Engine, Auto Trans (if equipped) and ABS modules information?
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
