send my file
send my file
Sorry Juan I don't understand.
Do you want me to send you my KMS files?
Best of luck its not just a switch their a string and the car spec and higher functions are within said string. And some of the new Hyundai are not on eeprom anymore
nearly all late Hyundai are micro based now...
hi smokingaces
... can you help me with Firmware Dump from Hyundai Grand i10 BCM .
i wanted to enable auto speed based door lock - in my car which has only auto door unlock.
i can use NEC programmer to upload the modified firmware.
i saw it in Russian form they had done it for Eeprom based BCM of Hyundai Solaris \ Verna .
any luck with that subject?
within a week i will have a tucson 2018 uk spec and need to make a display in km. So far only available is mph for speed and uk or us gallons. No EU measurements are available. Im wondering if EU dump will do the job.
Let me know if you get any info please. Ill load a dump when Ill get a car back.
cheers
Let me know when you have it I might be able to swap one with you.
Hi. I have the car now and i will have eu cluster next wednesday. I will read both and will see whats there. Ill post them here.
Update:
1. uk version 294mls Nec 70f35xx eeprom cluster part number 94001-D7CT0
2. EU version 22613km NEC 70F35XX EEPROM cluster number 94003-D7310
Unfortunately I cant write it with smok tool thru obd so i wont check if changes are working. I would have to connect to nec directly.
But maybe someone will find anything
Clock are interchangeable, no immo, no bdm data. Straight forward and all data are in km, km/h, l/100km
cheer J
Have you already ordered a KM version?
I was going to swap one with you for your Mph one.
Yes i got one from poland and already fitted and milage adjusted. So i can give you uk one for free. There is 280 miles on it (new car ).
Pick up in cork or we will organise shipping no prob.
Cheers J
Today I use Carprog for read write eeprom via OBD.
Change on adress 366 value F9 for miles/gallons and F8 for km/litres
Don`t forget to press "Thank you" if my post was helpful
alexpivtorak (19th May, 2021), claudio35 (17th September, 2019), Cod2020 (27th July, 2020), DarkDiver (11th December, 2020), den5 (23rd May, 2020), EGA3 (15th July, 2020), frontpager (27th July, 2020), jomberykaso (17th September, 2019), makarena2008 (20th June, 2020), nckryder (28th July, 2020)
Do you know where the language is? I checked in flash and there are some different, the question in which eeprom adress is it changing?
Anyone know something ???
Hello! Kuzmichh, I used the address and value you provided and it worked on both models, 2016 and 2018, however, digital speedometer still calculates speed in miles. how to change that???any ideas??? pls help.
Hello! I have tried Kuzmichh method and it worked! However the digital speedometer indicates the speed in miles instead of kmh! can somebody assist with this pls!!
see photo below. digital shows 38 kmh then analoge shows 38 Miles and analog kmh (smaller circles) shows 60 kmh. IMG_20200726_190307.jpg
