Help other, and we will help you,
Check your ecu id start with 103 before you write this file!!
If not the same, don't write and post your 103 number.
Let make your tool the checksum!
Pass sended by pm
Regards,
Hello guys
VIN: WAUZZZ8E48A030476
Bosch hardware number 03G906016LQ
System Type number R4 2.0 EDC G000CG
Multitronic 2007 BPW 2.0TDi
Most probably i have tuned firmware, because counter says ECU was modified 2 times.
I think Car consumes too much diesel and has too much smoke, so i think this could be due modified ECU firmware
So i wanted to program STOCK firmware with DPF OFF and EGR OFF
Today i downloaded firmware from ECu with MPPS v16 to save it as backup
Would be great if someone could share with me STOCK firmware with EGR and DPF OFF
P.S engine has silly modification with bottom block from 1.9 which means that head of engine is 2.0 but bottom 1.9 and previous chiptuning causing it to not burn all diesel which leads to more consumption
Sorry for long text
UPDATE: need 1037391502 STOCK EGR and DPF OFF
Pass sended by pm
Regards,
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Great, thanks to you.
I will check number today and report as soon as i tried this FW on my car
Update:
I have 1037391502 at the moment
Maybe someone have 1037391502 with EGR and DPF off? Need stock without map changes
Thank you guys
to help you i need to know sw and hw and i will find you file ori
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
This is what i have now:
