Results 1 to 7 of 7
    Apr 2018
    Default Audi A4 2.0TDI BPW Multitronic EGR, DPF OFF stock needed
    Hello guys
    VIN: WAUZZZ8E48A030476
    Bosch hardware number 03G906016LQ
    System Type number R4 2.0 EDC G000CG
    Multitronic 2007 BPW 2.0TDi
    Most probably i have tuned firmware, because counter says ECU was modified 2 times.
    I think Car consumes too much diesel and has too much smoke, so i think this could be due modified ECU firmware
    So i wanted to program STOCK firmware with DPF OFF and EGR OFF
    Today i downloaded firmware from ECu with MPPS v16 to save it as backup
    Would be great if someone could share with me STOCK firmware with EGR and DPF OFF
    P.S engine has silly modification with bottom block from 1.9 which means that head of engine is 2.0 but bottom 1.9 and previous chiptuning causing it to not burn all diesel which leads to more consumption
    Sorry for long text
    UPDATE: need 1037391502 STOCK EGR and DPF OFF
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Help other, and we will help you,
    Check your ecu id start with 103 before you write this file!!
    If not the same, don't write and post your 103 number.
    Let make your tool the checksum!
    Pass sended by pm
    Regards,
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Apr 2018
    Great, thanks to you.
    I will check number today and report as soon as i tried this FW on my car
    Apr 2018
    Update:
    I have 1037391502 at the moment
    Maybe someone have 1037391502 with EGR and DPF off? Need stock without map changes
    Thank you guys
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    to help you i need to know sw and hw and i will find you file ori
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Apr 2018
    Quote Originally Posted by AVDigitale View Post
    This is what i have now:
    Apr 2018
    Default Current firmware
