just post it...
Does anyone know how to remove the encrypted NOREAD sections from tuned files?
I have paid for a tuner to enable crackles and pops but they are pretty tame and he has stopped replying to me after taking my money so I want to try and see if I can sort it myself. I have removed the normal NOREAD via hex edit but still cannot open in latest OLS.
just post it...
DSG TUNING
File Service
https://1drv.ms/u/s!AoXscW7Dqf1QhVsy-brbiVWB4s0Y
Let me know if this works.
Use cracked 2.24 version and can open without issues.
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
kire106ka (16th April, 2018)
The definition file I have for my flash is in the newer OLS version unfortunately! I was going to get all the addresses from this flash, then add them manually into 2.24 so I can edit.
Ive asked on various places but no one has a definition file for this ecu and soft for 2.24.
A4 2.0 TFSI 220
8E0907115D
0261S02211
1037386863
that file can killing your engine :-) use 115h damos 5 min work and u have your mappack
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Its really annoying. I don't know much about tuning these engines yet, but Ive paid good money for a supposedly good tune. Which bits need sorting?
Spec of car currently:
VIS motorsport HPFP
RS4 FPV
decat & catback miltek
uprated clutch
CAI
This is supposed to be an interim tune whilst I source FMIC, injectors and ko3 hybrid / modified ko4 at which point I plan to get it tuned properly on a RR.
Do you have the 115h damos to hand? Ive had a look through the stuff I have but don't have this particular one.
all can be done with proper logs. Med 9.1 isnt hard to tune.. If you want good tune just contact with us.
regards
DSG TUNING
File Service
post the file i will remove for you
Chip tuning custom Stage 1 2 3 egr, dpf, dtc, hotstart lambda etc...
24/7 Online support
Skype name on my profile
